I wrote an email to tech.eu@mcneel.com but I was told to create a forum post with my issue, so here we go:
I am evaluating the Rhino 7 now and I have run into one major problem - poor performance with relatively small point cloud. It is especially problematic for me because my company specializes in delivering data from point cloud.
I was told that in Rhino there was no software limit for models and point clouds and the only limitation is my computer, which I consider to be quite powerful. Its specification is as follows:
Unfortunately, after importing point cloud from a laser scanner, Rhino starts to freeze/lag. While Revit and Recap handle the original point cloud without problems, Rhino has trouble working with the resampled cloud.
Original point cloud: +500 000 000 points, ~20 GB on disk (Recap project)
Resampled to distance between points of 1 mm, 350 000 000 points, 6.5 GB on disk (e.57) ← this one freezes
Resampled to distance between points of 5 mm, 66 000 000 points, 1.2 GB on disk (e.57) ← this one works ok
In my email to tech support, I also shared a link with point clouds but I don’t want to do this in open forum. If someone from McNeel would like to investigate the problem I can share it again.
I would be grateful for any help with my problems. So far, I find Rhino to be a really good piece of software, but this bottleneck with point clouds may shade all other benefits since it is critical for my business.
Kind regards
Seweryn
