Plug-ins package manager Rhino MAC
Hello!
I was trying to install some plug-ins on my MAC Rhino 8 using the package manager (which works like a charm on my Windows). But I simply can’t… the Install button does not show up, so I’m left on “the following package will be downloaded and installed” and nothing happens, as you can see on the screenshot below:
I noticed I have other plug-ins that are actually installed (according to the package manager…) which means at one point it worked, and now it doesn’t? is it because of these specific plug-ins? Should I be using a diferent version? I also tried doing it the old way by downloading from Food4rhino, but they redirected me to the package manager…
I have been trying to find a solution, but it’s been hard ahahha
If someone can help , thank you!
Ah yes, that was logged a few weeks ago here → https://mcneel.myjetbrains.com/youtrack/issue/RH-89655/PackageManager-install-dialog-not-showing-buttons-on-Mac. There should be a fix released today in 8.25 RC1
Some workarounds can be found here → Error Installing at Paketmanager
Package Manager still out of order!
What version are you using @Martin_van_Oene?
Hi Callum,
I’m using the latest version 8.24.
In RH 7 it’s working like a charm.
Is it possible to swap items from the RH 7 package library into the RH 8 package library?
If you update to 8.25 it should be fixed, but the linked thread has some workarounds you can use :slight_smile:
:+1:
RH-89655 is fixed in Rhino 8 Service Release 25
