Hi everyone,
every time I try to oper Grashopper in Rhino 8 there is a plugin Dlubal that can’t be loaded properly with this mesage:
An error occured during GHA assembly loading:
Path: C:\Users\ME\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Dlubal-plugin\8.608.11.1\GrasshopperRfem6WsComponent.gha
Exception System.TypeInitializationException:
Message: The type initializer for ‘’ threw an exception.
Exception System.OverflowException:
Message: Arithmetic operation resulted in an overflow.
I already tried to unistall and install it again with no luck. I’m trying different way to solve the issue (repair rhino, install/uninstall rhino, install/uninstall plugins) without any luck. There’s someone can help me.
Thank you.
I’ve tried uninstalling the plugin using the Package Manager, deleting the folder containing the file, and installing the plugin. But when I open Grasshopper, the same message appears again.
You can try launching Grasshopper with the GrasshopperLoadOneByOne command and then deny any 3th party plug-in to load. If that works fine, you’ll have to use that command to try and find out which plug-in is triggering the error.
