Hello there. its my first time here with a query i hope someone helps me out. i have been visiting rhino forums several times for helps and its a great platform for studens and designers all around the globe. well the questions is im using subd to make this distored sphere with 3’ Diameter and now i am thinking of making it in grasshopper. can someone please guide me through to make it possible. Thanks alot!!! Creative WebGL Blobs | Demo 1 | Codrops
Hi
What is your goal? where are you stuck? what have you tried already? Do you have any sample files/ screenshots?
EXTRUDE_MESH_FACE-NORMAL_FINAL.gh (16.8 KB)
was manipulating this to reach the goal. No luck And that kind of experience so far
The file you sent, does not have geometry internalized. Try to internalize, and re-upload.
Also, check this link, on how to ask effective questions on the forum, so it is easy to help you.
it was just a sphere sir. any sort of round sphere converted to mesh
Check this out!
Made with a little noise and some twist!
I’ve used one component from the Noise 4D plug-in to generate simplex noise. You can get it on Food4Rhino or in the Rhino PackageManager!
Note that your reference was most certainly done with shaders.
noisy_sphere_ex.gh (16.2 KB)
thanks alottttt!!
