i would like to return by a script the angle between two planes, since this morning, i tried 5 or 6 kind of script, with rs.angle(), and rs.angle2, but it doesn’t match as i want.
my last script:
def AnglePlanPlan(planT,planM):
#uplanMDomain=rs.SurfaceDomain(planM,0)
#vplanMDomain=rs.SurfaceDomain(planM,1)
ptplanT=rs.EvaluatePlane(planT,[0,0])
ptplanM=rs.EvaluatePlane(planM,[0,0])
inter=rs.PlanePlaneIntersection(planT,planM)
ptmid=(inter[0]+inter[1])/2
lineinter=rs.AddLine(inter[0],inter[1])
inter90=rs.RotateObject(lineinter,ptmid,90,planM.ZAxis)
normal=rs.VectorCreate(inter[0],inter[1])
rotateplane=rs.RotatePlane(planM,90,rs.CurveEndPoint(inter90)-rs.CurveStartPoint(inter90))
#rs.AddRectangle(rotateplane,500,500)
inter1A=rs.PlanePlaneIntersection(planT,rotateplane)
inter2A=rs.PlanePlaneIntersection(planM,rotateplane)
angle=rs.Angle(ptmid,inter1A[1],rotateplane)
print angle
return angle[0]
def Plan(surf):
Usurfdomain=rs.SurfaceDomain(surf,0)
Vsurfdomain=rs.SurfaceDomain(surf,1)
u=(Usurfdomain[0]+Usurfdomain[1])/2
v=(Vsurfdomain[0]+Vsurfdomain[1])/2
eval=rs.EvaluateSurface(surf,u,v)
vect=rs.SurfaceNormal(surf,[u,v])
plan=rs.PlaneFromNormal(eval,vect)
return plan
def TAutomatique():
edge=rs.GetEdgeCurves('sélectionne le bord de surface à tenoner!',min_count=1,max_count=1)
if edge== None:return
surf=rs.GetSurfaceObject('selectionne la surface à mortaiser!')
if surf==None:return
planT=Plan(edge[0][1])
planM=Plan(surf[0])
angle=AnglePlanPlan(planT,planM)
print angle
rs.DeleteObject(edge[0][0])
pass
if __name__ == "__main__":
TAutomatique()
in fact i have 2 planar surfaces, and i want to return the angle between this 2 surfaces.
rs.angle2() always return the smallest angle, and rs.angle() return the angle on a plane, and it’s here where i stopped, i don’t find the good way for the construction of this plane, to return every time and every configuration the good angle
