Plane Curve Intersection Fails
When I run the attached Rhino Script and try to intersect the scripted plane with the curve (polyline) in the attached Rhino file (in Rhino 5 32bit) I get the output “Oh Dear”, i.e. the intersection fails.
Is this a bug or am I missing something?
Thanks!
Michael
PlaneCurveIntersect.rvb(314 Bytes) TestCurve.3dm(31.9 KB)
Hmm, does seem like a bug here - only happens with line-like curves that cross the plane at right angles. It is also happening in other planes in my tests here…
OTOH, it is working in Python
crv=rs.GetObject("Get curve",4,True)
#plane=rs.WorldZXPlane()
plane=rs.PlaneFromNormal((0,2,0),(0,1,0))
result=rs.PlaneCurveIntersection(plane, crv)
if result:
    pt=result[0][1]
    print "Intersection is at {0},{1},{2}".format(pt.X,pt.Y,pt.Z)
else:
    print "Oh Dear..."
I guess someone like Dale needs to come in on this one…
–Mitch
Yep, definitely a bug. I have fixed this for the forthcoming SR6. Since the curve is really just a line, you can use LinePlaneIntersection (instead)…
