Hi there,
I have a plane and curve that clearly intersect :
I’m running a CurvePlane intersection using model absolute tolerance set to 0.001 and fails to get a result. Reducing the tolerance to 0.01 works.
Given that the curve and the plane intersect, I don’t see what the tolerance has to do with it ?
Also moving the plane a bit with the same tolerance works.
Version : Version 8 SR8 (8.8.24170.13001, 2024-06-18)
snippet and model attached :
import scriptcontext
from scriptcontext import doc
import Rhino
import Rhino.Geometry as rg
TOL = rs.UnitAbsoluteTolerance()
#TOL = 0.01
s, plane = doc.Objects.Find(rs.GetObject("plane")).Geometry.Faces[0].TryGetPlane(TOL)
crv = doc.Objects.Find(rs.GetObject("crv")).Geometry
print Rhino.Geometry.Intersect.Intersection.CurvePlane(crv, plane, TOL)
250206_CurvePlaneIntersectionFail.3dm (61.4 KB)
Edit :
The same model and code works in Rhino 6
250206_CurvePlaneIntersectionFail_RH6.3dm (58.8 KB)
