Hello
I think you can use Minkowski difference, it is in Clipper plugin
You’ll have to place your rectangle centered on 0 on XY plane (or other if you specify)
Then plug this rectangle to A and your polygon to B.
It will output 2 curves. The second curves is the maximum polygon to place the rectangle inside your polygon. WIth that you could find the optimum position
rectangle inside polygon.gh (12.5 KB)
