I am trying to mirror an object when it is arrayed ten or more times. I´m using a very simple Python script do make the True or False statement. But it’s not working. Both Python and GH codes seems to be OK.
Somebody have an idea what am I doing wrong?filterWpython.gh (12.8 KB)
You renamed the out of your Python component to “mi”, however this output is reserved for execution information. You should output data trough the default output a or other outputs that you can add if needed. Those outputs can be renamed as desired.
