Path Compare.gh (13.7 KB)
Hi there,
I wonder how are these components not working as what I think with those red pen selected to be true.
Is there anything misunderstanding with these components.
And how could I do to match what I want?
Thanks,
regards,
if you plug lists of different length, they are usually interpreted as if the last element of the shortest list is repeated until the length of the initially_shorter list becomes equal to the longer one:
this also explains why the element at index 13 being True looks kind of weird
by the way, as your tree has no branches, the comparison is done index-by-index from list a to list b
so it will result True only if item at index x of list A is equal to the same item at index x of list B
If you use Longest List, then you’ll understand what @inno 's said.
Thank you, Adam,
I’m just currently learning how to code,
and definitely will get to know it.
but never thought it will be this ease! ![]()
Cheers!
If not restricted by the rule of seeking the easiest and the fastest approach only,
it’s still funny to scout any possible solutions within those limited components,
thanks for sharing the good-skill again! ![]()
