hello everybody,
currently working in a projet of façade panels, i was wondering how to stablish a numbery system in order to identify the panels with same dimensions and perforations,
so i have a multiples lists with a {A,B,C} path, the data inside those list is the distance between 2 perforations, so i need to compare the lists with the same {A} in order to identify panels with the same features, if all the lists inside {A} are identic, create 1 path (like case 2,3 and 4); if there is 2 variants inside the {A} path, create 2 paths; if all lists have differents lenghts (like case 6) create individuals paths
Panels are already sorted by surface, panel with the same area are inside the {A} path
thank you for your support!
