Patch Layout
I came across an image showing the patch layout of a beautifully designed frame.
There are several pentagonal and hexagonal openings—do you think these surfaces were created using “Patch” command?
I’ve highlighted a few areas in different colors on the image to make them easier to identify.
I’ve also included the link below for reference.
https://www.chapter2bikes.com/product/rira-altra-ud-gold
Thank you!
I don’t think this is Rhino.
This kind of pena/hexa faces were impossible to achive with the previous version.
The V9 has a rewritten patch command that’s absolutely able to do this.
So yes, this is a patch, a V9 patch.
Hi skysurfer,
Thank you! I’ve been curious about this for a while, so your explanation was really helpful. I’ll definitely consider upgrading to Rhino 9!
It worth it :+1:
Don’t forget Xnurbs can do this as well.—-Mark
just to be said:
the company may also decide not to publish the correct surface / patch layout and fake the Isocurves / Edges because they want graphics with engineering style…
(photoshop or ai (above)).
1st hint on fake-isocurves:
why does a revolve have those isocurves ?
2nd - many transitions are solved with huge amount of surface patches - but this complex transition is not - even if the straight part is mostly a simple extrusion…
my 2 cents - kind regards - tom
Thanks for the tip, Mark! I’ll keep XNurbs in mind as well.
Hi Tom,
Thank you for sharing your thoughts and pointing out these details. That’s an interesting perspective. I hadn’t considered the possibility that the isocurves and edges might have been added artificially.
I’ll probably have more questions as I continue learning, so I hope I can count on your help and advice here on the forum in the future!
Thanks again!
It’s totally possible to achieve such patch surface with older Rhino versions. Like 20 years ago.
As for the multi-side surface, in the early days of Rhino 2 I used this trick to achieve similar transitions. Over-build, then trim away the unnecessary portion at the top.
That’s the way to do it even today. Nothing beats a good old 4-sided NURBS surface : )
This looks like parametric goofy stuff going on there reminds me of that dog water of a software called CREO.
Just sketch a good surface patch layout and you can do this with nurbs smooth and clean you don’t even need gimmicky stuff like patch in v9
Spend time with nurbs it’s more capable than you think.
