Draw/show isocurves of patch surface from GH?
Is there a way to show/display the isocurves of surfaces in GH? Similar to checking/unchecking the “show surface isocurves” check box in the surface properties in Rhino?
(pink are patch surfaces in GH, grey are baked into Rhino Document)
Note: The patch surfaces are made with a ghpyhon script that uses a U and V input. We want users to be able to “see” the UV density on the surface as they are designing.
The method we are using:
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Brep_CreatePatch_1.htm
Try the wireframe component.
You can also use the “Iso curve” component if you want more control:
@Michael_Pryor Son of a…that’s exactly what I needed. Thanks pal. I should have looked a little deeper. That lead me right to the rhinocommon method I was looking for!
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Brep_GetWireframe.htm
@andheum , thank you friend! The python code I’m using for the patch surface method, is actually based on something you posted on the old GH forum!
You shouldn’t even need to script it anymore - I wrote that back before there was a native patch component in GH!
Good point! In our case, we needed the UV input for some specific “fine tuning” for certain bits of terrain that will ultimately end up in revit. The builtin Patch component only has spans. Admittedly, it’s a bit of an edge case scenario, but it’s something we come across frequently enough!
