Parametrice this
hello, anybody can help¿ I attach an image, at the begining we only have the five lines in the left and the vertical ones. I wanto to draw the blue line. It comes from the intersection of the five lines with the verticals but moving down to the new intersection the diagonal ones. I mean I can do it five times doing it with componentes but I want to parametrice it because I could have much more lines. Hope I coul explain myself. Thanks
I think you forgot the image
yes
I did edit it to paste it. Thanks
Are the red lines fixed rotations from each other or is each a different angle?
It could be different angles, in this case is the same but it could be different.
nobody knows how to do it? Thanks anycase
Continuing the discussion from How to ask effective questions:
Also, corporate.
try this. Requires Anemone.
dotheworkforme.gh (16.3 KB)
Thanks, i really tried it a lot without anemone and I could not get it, i will try with anemone, thanks a lot
Also works with a list of numers for the distance.
the last one requires anemone?
? Both scripts are the same. Both require anemone.
