Parametric triangle
Although there are discussions similar to my problem I cannot find a specific solution and would appreciate any advice.
I have created a parametric triangle where the length of the base line is determined by the height of the wall and the angle beta……At first I used an expression with x.cos(y) and then I found the trig component so I used that instead.
What I don’t understand is why I cannot control beta below a value of about 30 ……the slider reads 6 but the angle is clearly greater than that.
I must be restricting something somewhere but I cannot see where.
Any help would be much appreciated
triangle.gh (11.4 KB)
Because you were using the ‘R’ output instead of ‘P’.
triangle_2022_Nov10a.gh (9.2 KB)
thank you Joseph
