Parametric Surface Deformation Using Grasshopper?
I‘m a researcher at a lab, we design prosthetics that help people with foot injuries walk. Our process involves 3D scanning patients‘ legs and processing the scans in Rhino, including adding 'releases‘ which help alleviate painful pressure points.
Our current process includes converting the scan to SubD, splitting the surface, offsetting it using OffsetSrf, and then BlendSrf. It‘s a rather finicky, time consuming process, which means it takes more time to help our patients.
Would it be possible to add these bumps parametrically using something like Grasshopper? A brief search brings up Lunchbox or Pufferfish but they don‘t seem just right.
Any ideas would be much appreciated!
Are you aware of shrinkwrap?
I wasn‘t. It seems like it could be part of the puzzle though i‘m not quite sure yet, I‘ll have to experiment.
I wonder if i could create the ‘releases’ in grasshopper as separate objects then shrinkwrap and quad remesh
hi @Yahli
What exactly are the ‘releases’ and what are the ‘bumps’? Pardon my ignorance, could you be more specific?
Of course! The releases/bumps are the raised areas visible along the shin in the second picture
Hey @Yahli I know it’s been a minute, and thanks for the clarification.
By ‘add these bumps’ do you mean parametrically making {from scratch} the structures that influence the bumps or affecting the surface with pre-modeled structures?
:man_shrugging:
Do you have an example file + further clarifications? :slight_smile:
Cheers!
