Parametric Profile Tekla Live Link
To learn to use grasshopper with Tekla for AEC work I am doing a small steel building (below) as a test case. The foundation slab requires a concrete thickening that uses a TRPZ profile. In Tekla you can input the dimensions required behind the “TRPZ” text and it will create the profile. When I build a CC in Tekla I can use variables to define the profile. Is it possible to drive the profile dimensions using grasshopper fields? I know I can add the profile to the catalog, but that is an easy step to miss.
Thank you. I feel silly about the Q now.
