Hello, I’ve created this facade in rhino but I would like to use grasshopper to manipulate the module by the use of attractor curves to generate the same effect than in the picture. It’s a 35cm x 15cm grid, and each block has a division. The segment that materializes that division is the one that should adapt to the attractor point, by variating in its separation from the wall and its position in its block.
prueba panel 31.7.3dm (4.9 MB)
