when trying to update to a newer version of the plugin from a local yak repository, our users get an ‘ID already in use’ error. Uninstalling the existing version and installing the update works fine.
Is the plugin GUID supposed to change with each new release? We’re on a very fast release cycle and push updates a few times a week.
We’ve seen this error intermittently over the last year with our ZebraCut Plugin with both Rhino 7 and 8.
Though I’ve not seen it for a few months.
The last time I saw it I was able to confirm it was occurring because the user had 2 instances of Rhino open during the package update and I assume the uninstall fails because the plugin is in use in the other instance. Might be the same issue or might be entirely separate.
For us, it might be related to the fact that the plugin registers a panel which is open when users try to update. Still, it would be great if this could be resolved.
yes we also have such a panel. Our technical support teach to manually uninstall and then to install on Rhino 7. For Rhino 8 we’ve had no issues with the auto-update.
yeah we’ve not seen any issues with Rhino 8 I suspect it may still happen with 7 but we are not releasing very frequently for that as all our dev now is focused on v8.
What we had to do is set up our R7 deployments to happen via the CLI for yak.
We use something like this as a batch script that get’s run with Rhino closed.
At the moment, we’re using a shared drive and they’re using the batch file directly. It’s a purely internal tool, so while this isn’t how I’d like to do it, it covers our use case.
Options we considered:
distribution via a shared drive (box / dropbox / onedrive / etc) <= what we’re currently doing
Batch files and *.yak files live here
Provides Limited Version Control
Only really suited for a small, internal user base
distribution via installers
Batch files and *.yak files are packaged into an installer
Installers are then distributed, downloads, links, etc.
This has the benefit of being something that a larger enterprise IT team will be used to accommodating, but you’ll probably need to set up the installers
This does not really work for a project that you’d like to distribute externally via Yak
I don’t recommend doing this unless there’s an existing distribution mechanism that requires you publish via this mechanism.
Share the batch file (either raw or inside of an installer), distribute the project via yak.
This is a good option if you’re distributing externally
The installer / batch file then is there to provide a work around for R7 users, but you can probably avoid having to create new versions of the installer for every update and instead just publish to which ever package repository you’re using.
In general, doing all of the configuration management via the CLI means that when a user installs or updates rhino, I’m able to make sure they get the standard set of plugins that everyone else on the team works with. Not a huge concern if you’re making a plugin for external use, but its really saved us time internally.
Our company is quite large, with multiple offices around the world and we’re already using a custom yak repo on a shared drive. We also have an exe file on a shared drive, which automatically adds the necessary path to PackageManager’s settings. Rhino 8 has an auto-update feature which allows us to set things up once on user computers and then simply push updates to the shared repo.
We’re in the process of transitioning to R8, but for the foreseeable future need to support R7 as well.
If you’re already using a custom yak repo, I’d just deploy the batch file as part of your install for Rhino 7 and push it out to those that already have it. It’d be manual in that users would need to run it, but it would at least make sure the install is happening correctly.
As far as having it behave more like the R8 auto-update, you could setup your own service on users machines that waits for all Rhino 7 instances to be closed and then run the update script if necessary. This may or may not be worth the effort as you’d need to prevent users from starting rhino while the update was running.
You should reach out to the developers of Sparrow. This is almost certainly a case of either a shared template or AI generated code. I point you at Sparrow as a opposed to Swiftlet given the age difference in the plugins. This error occurs when two people use the same GUID in their C# code. There’s a support email link on FoodForRhino: https://www.food4rhino.com/en/app/sparrow-0. There’s nothing that the good folks at McNeel can do about this.
