Hey @Arthur ! I first would like to thank you for your incredible plugin! I am however having consistent issues with the Ray Tracing module as it has been giving me two consistent errors the first being:
“1. Solution exception:Cannot access a disposed object.
Object name: ‘Convergence_Progress_WinForms’.”
I believe this error occurs when there has been multiple instances of the calculation program that pops up when using the Ray Tracing Module and disappears when I reload the file. I am curious if you know a way around this error? I have tried to quit the processes for the popups using task manager and then re-enabling the Ray Tracing module but that hasn’t worked. The only thing that has is saving and reloading the file every time. Any insight would be incredibly helpful!
When I am not getting the above error I am receiving this error:
“1. Raytracing operation failed. This can be due to an unsuitable scene object. For example, did you set materials on all layers referenced by Rhinoceros Geometry?”
I originally received this in quite a complex model I was trying to acoustically analyze so I created a simple test file following the tutorials by AREA only to receive this error again. I however opened up the reference files: “Open Office” and “Office Noise Display” which had no issues opening and running. Super confusing but it leads me to believe that I haven’t assigned the materials on the layers correctly? Which is odd as I followed the tutorials (the file is in meters) and now with no apply material button it is done automatically as I selected the layers and changed their absorption coefficients. Please let me know what I am doing wrong it would be incredibly helpful. Thank you so much for this plugin again, and for your time!
Best,
Jack Ironside
