HI, I want to delete overlapping faces from a list , How can I do that?
I made my faces with loft component between 2 polylines shapes like this.
thanks!!
thanks!!
If surfaces overlap then you can check for this by using one of the surface intersection components. Or you could extract edge curves and see if they intersect. Then use a dispatch component to get rid of those that intersect. Many ways to skin a cat.
From the looks of it though your surfaces don’t overlap. Maybe share the file so we can see whats going on?
Ok here is the file. I want to explain my work for a moment: for my thesis I am working out how to build a pavilion with cardboard boxes. however, they are not cubic, but have the shape of pyramid trunks. The bases will be arranged towards the outside so as to be tangent plans to the surface given to me by the hypothetic customer. the entire system must have an important formal constraint: the faces of the pyramid trunks MUST, of course, be adjacent and belonging to the same plane, so that they can be connected together in reality with bolts or clamps.
In my definition I have a problem: these faces seem to have suffered a twist!
I’m sorry for all these questions and thank you so much to anyone who can help me!
tool.gh (32.8 KB)
