I have a Hops script that returns different geometry when used live compared to when pointed to as a hops component. The hops script itself works as desired; I’ve tested this by internalizing the data used for the inputs and copying it through to the hops script. I’m also isolating one branch at a a time (for each input). When doing this test, the script returns the desired geometry.
However, when pointing to the hops script and feeding it the same inputs, even when isolating a single branch, the component returns different geometry.
Any ideas on what could cause the difference?
