Same issue for me. Not only does Osnap not work, but smart tracking doesn’t work at all either. Rhino 7 geometry and Rhino 8 geometry both not working
Rhino 8 SR3 2024-1-9 (Rhino 8, 8.3.24009.15001, Git hash:master @ 3541fa287a013b0f17849f0740f1e43a44031bfc)
License type: Evaluation, build 2024-01-09
License details: Cloud Zoo
Expires on: 2024-04-21
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4070 Ti (NVidia) Memory: 12GB, Driver date: 8-14-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 537.13
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-14-2023
Driver Version: 31.0.15.3713
Z-Buffer depth: 24 bits
Total Video Memory: 12282 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.3.24009.15001
Hi Patrick - does this happen in a layout or model space? If in model space is there a layout or multiple laypouts in the file? Does it happen in a new, clean file with only a box or something, or only in files with many objects?
I’ve tested in layout and model space, in files I created in Rhino 7 and opened in 8, and yes, even in files I’ve created only to test the function. Simple geometries in new Rhino 8 files don’t even work, which I tested in “normal” as well as safe mode. I’m going into the office now and will check on a different pc today.
Hi Pascal, I have tested Rhino 8 on a different pc with the same result. I had no issues on either with Rhino7. Is there something I don’t understand about how these functions work differently in 8 from 7?
Thank you
Hi Patrick - they should behave exactly the same as in previous versions - what may be amiss here is the Osnap panel itself - on the left by default - can you send a screen shot of how that looks - where ever it is - on your system?
I’m the idiot, I’ve used the panel you circled and everything is now functioning properly. Thank you for your help!
