Osnap not working Rhino 7
I have the same problem with Osnap not working, it won’t turn on, and I’ve tried everything you have mentioned above… please help:(
this is the systeminfo:
Rhino 7 SR36 2023-12-12 (Rhino 7, 7.36.23346.16351, Git hash:master @ 11a364321297eb8cdb34405a3308d8911f58706d)
License type: Educational Lab License, build 2023-12-12
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 15Gb)
Primary display and OpenGL: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 12-16-2021 (M-D-Y). OpenGL Ver: 4.6.14761 Compatibility Profile Context 21.30.23.04 30.0.13023.4001
> Integrated accelerated graphics device with 5 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 12-16-2021
Driver Version: 30.0.13023.4001
Z-Buffer depth: 24 bits
Total Video Memory: 512 MB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.36.23346.16351
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.36.23346.16351
Hi, the osnap is not working on my rhino 7, I’ve tried everything (including statusbar and testResetWindowPositions), but nothing changes. Please help me!
This is the systeminfo:
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Hei Synne -
Could you describe what that means? When you run the Osnap command, can you set the options?
Your GPU is rather underpowered and running on very old drivers. I’d open the Notifications panel in Rhino and follow the links to see if there are newer drivers available.
When I click the osnap, the layout kind of only zooms in and out a bit, yet it doesn’t turn on. So when I for example try to draw a line from a point, it won’t snap to it. I tried downloading a new driver, hope it helps, thank you! But how can I fix the osnap further?
I can set options, but it doesn’t help anything that I have tried.
I updated the driver, and this is the new systeminfo:
Primary display and OpenGL: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 2-20-2024 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 24.3.1.240216
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 2-20-2024
Driver Version: 31.0.21912.14
Total Video Memory: 8126 MB
Hei Synne -
I’m not sure if that means that the checkmarks are not appearing in this panel:
Thank you so much!!! It works now :smiley: wish you a wonderful day, and thanks again :blush:
Synne
