there is a Rhino.SelectionFilterUseCheckedColor
what about the Osnaps?
You can check out this thread.
that unfortunately changes the background of all buttons not just the osnaps and does not match the general highlighting then which is controlled at the OS level of mac which mutes the color additionally and is therefor rather a mess trying to match up, if possible at all. so if you set the exact same color you get this
so either having both in one option or introducing the obvious missing one would be helpful.
We’re likely going to remove the dedicated color. This was part of a UI experiment in v9 wip to help distinguish the Selection Filters from OSnaps which were both just check box lists when the project started. It’s why it’s hidden in advanced settings and test commands.
OSnaps follow Rhino’s “state button” UI theming as Selection Filters should also now that we have icons and a new UI layout but will likely remain an advanced feature.
thanks for responing @Trav
does that mean that the colors will all be unified (again) from within MacOs settings soon? or does it mean that there will be one unified setting for all the background highlightings? using too many means of differentiation can indeed get in the way, happy that this was just a “hick up”
for me the words and location are enough, and it was a bit of a challenge to artificially unify both backgrounds to calm all that down, generally Rhino has become a bit screamy these days..
It means all of the “state buttons” share the same settings with the odd exception of selection filters which might fall in line again at some point now that we’ve fixed the original problem in several different ways.
apologies for the persistent misunderstanding on my side.. does that mean that soon we will have no option at all to unify the looks of the hightlights till this has been completely figured out?
the opposite. It means if the test code is removed for selection filters it will share the exact same color value as all of the other state buttons. OSnaps, Status Bar, etc.
