Blurry icons
Osnap and Selection Filter icons look blurry. This issue does not occur in other containers.
Screen resolution: 2560x1440
Screen scale: 125%
Regardless of the topic, can we change the active button colors of these icons? Especially the yellow shade of the selection filter—it’s barely noticeable.
System information.
Rhino 9 SR0 2026-9-29 (Rhino 9 BETA, 9.0.26272.12303, Git hash:master @ b5f5102690615c89acabfc68e24eae200f3d735b)
License type: Commercial, build 2026-09-29
License details: Stand-Alone
Expires on: 2026-11-13
Windows 11 (10.0.26300 SR0.0) or greater (Physical RAM: 16GB)
.NET 10.0.7
Computer platform: LAPTOP - Plugged in [53% battery remaining]
Hybrid graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 5060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 9-4-2026 (M-D-Y).
Integrated accelerated graphics device with 4 adapter port(s)
  • Laptop’s primary display device
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 2GB, Driver date: 6-17-2026 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Users\Aziz\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\BlockEditNew\2.1.7\blockeditnew.rhp “BlockEditNew” 2.0.0.0
C:\Users\Aziz\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\height-beta\3.9.12\net8.0\HEight Beta.rhp “HEight Beta” 3.9.12.0
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoAI\net8.0\RhinoAI.rhp “RhinoAI” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26272.12303
C:\Users\Aziz\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26272.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Thanks!
You’re right! These are still missing their sizing + display scaling offsets. For today, you can head to Rhinos Options > Advanced and type in OSnap and set the OsnapIconSize to a larger value.
RH-99332 Osnap icons need display scaling support
Thank you. So, is there anything that can be done about the button background colors?
Run the TestOSnapToggles hidden command. You can find several color customizations there. The buttons follow the same color states as the status bar with Selection Filters having a couple additional overrides to make them more distinct which can be disabled or changed.
Thank you.
Note for anyone who might look at this post in the future: You can change the colors of the Osnap buttons in the Rhino.UI.ThemeSettings.Frame.Button.Checked.Background advanced setting.
RH-99332 is fixed in Rhino BETA
