Hello!
I was wondering if i could get any help with the attached file
I have a componet that i need to orient to a set of target curves, all of them work but one.
Any ideas
Thanks for your hep
COMPONENT.3dm (136.3 KB)
COMPONENT.gh (10.3 KB)
Hello!
Any ideas
Thanks for your hep
It is a bit hard to see if what I did is the solution you need.
If I am correct, you used quit a “workaround” to get what you want.
You can directly use the CENTER’s you have. If you input them straight into the ORIENT component, it seems to me it works alright. (and if so saves you a lot of components)
Regards, Eef
COMPONENT orientationEW.gh (16.5 KB)
The plane was flipped - here is one way to flip it back
COMPONENT.gh (14.1 KB)
Thank you so much Eef and Artstep.
Eef’s method works for me, i am surprised in it`s simplicity
Thanks again
Then you may set the solution check ![]()
done, thanks again
