Hi. I was excited to learn about optionsmigrate. In theory it saves us a lot of headache. Unfortunately it complains and fails to migrate from Rhino 8 on my company-issued machine. Quite likely to do with admin rights missing but the command only mentioned a backup could not be created. If its admin rights then it should say so, no?
Then again, If I go through the pain of transferring all settings from one computer to the next manually then I do not need admin rights. Ideally it is the same for optionsmigrate.
If you run TestEnableDebugLogging before running OptionsMigrate, it’ll drop a txt file in documents that if you put here I can take a look at and we can figure this one out. In theory it should not need admin rights.
If you then try running OptionsMigrate again, and make sure to explicitly click on the previous version that you would like to migrate from, does it work then?
By default, the previous version (in most cases, Rhino 8) is highlighted, but I’m not sure if it’s actually selected?
