Opossum optimization Objectives NaN ERROR
I am trying to optimize my architectural building.But having the same error all the time can anyone help please.(I cannot add the code because its above the upload limit which is 20mb)
Hello @burak5,
Were you able to work around it? I am having the same issue
Hİ, yes i did. Its something related with the code , when the algorhitm working there must be some value that becomes ‘‘0’’ its because your code is not working well, there must be a mistake when the parameters change, the value become ‘‘0’’ then opossum thinks that ‘‘0’’ is the best score that he can found so it stops.The solution is add a list to a value to number than cull all zero’s and others than it will work. I dont know if i make myself clear but try if you cant ,write me again i will help you.
