Opossum error: failed to cast objective value to double
I am running an optimization using the wonderfull Opossum plugin and get this error:
Capture
the GH definition is pretty messy right now so I won’t upload it. generally the case is to minimize some numbers and have few constraints that when the solution is contradicting them I add a “penalty” and replace the grade (objective) with a high value.
anyone can help???
Hi Sisoburg, did you solve this problem? I´m experiencing the same right now. Thanks!
