Open Street Maps to Grasshopper using C# & Visual Studio
Maybe you have some tips for tutorials, that show how to create a custom C# component using Visual Studio Template and connect this component to open-sourced maps, i.e. Open Street Maps.
For example I would like to create component from scratch, that will show which amenities I can find in certain area of the city.
I’ve tried to use Gismo, but the plug-in doesn’t have all the functionality, that I need. So my plan is, to create all the components I need using C# and Visual Studio template.
I’ve downloaded the template from here: Release 7.13.0 · mcneel/RhinoVisualStudioExtensions · GitHub
Thank you in advance for any tips!
Hi @Alena_Mishkevich ,
if you have zero experiences in creating components in C# for GH, it probably would be good to learn the basics before you move to a more advanced topic(like the OSM thing).
There are plenty of resources of that topic, some of them you can find in this thread:
Luis from parametric camp is showing exact this topic (very detailed) these days here.
Also, learning c# is very fun, but if you just want to expand Gismos abilities, maybe @djordje could help on this.
I would second Baris’ comment.
Which kind of amenities search are you looking for?
Hi @Baris Thank you for tip! I’ve already watched the videos from parametric camp and finished some courses about c# syntax, methods etc.
So I am ready to move to the next step and start working with OSM. Therefore I am looking for some related to this topic tutorials or courses
Hi @djordje
Thank you for your replay!
I’ll give you an example of what I am looking for:
INPUT:
  1. a region in the city (could be polyline, could be list of coordinates of the boundaries or something else)
  2. Location (a point or coordinates)
    OUTPUT:
  3. list of all the amenities I can find in the region
  4. Distance from the point (input) to each amenity
Therefore I need to know how to use Open Street Maps to create a custom Grasshopper Component.
Since your question about how to use the template I supposed you haven’t watch any tutorial on this. Sorry
Check the attached file.
It requires Gismo and ShortestWalk grasshopper component.
It sadly can not find all amenities within defined rectangle, but only those which you define to search:
closest amenities.gh (184.5 KB)
If you @Baris didn’t understand my question, it is not the reason to tell, that I have lied…
Anyway I’ve found a helpful tutorial how to connect API to a C# template in Visual Studio. I’ll try to apply this on Grasshopper C# template and Open Street Maps.
For some, who need this information, here is the tutorial: https://tutorials.eu/build-a-currency-converter-application-using-wpf-in-c-with-api/
Thank you, it definitely will be helpful!
