but it doesn’t suit well to me.
It correctly works on main thread (e.g. into a Rhino command) but it does not in working threads.
It freezes the application.
It would be nice to have a single function capable to convert any type of geometry supported by Rhino into an ON_Mesh, but also a specific function for SubD would be fine.
How can I convert a specific ON_MeshParameters into a ON_SubDDisplayParameters?
Doesn’t exist a single generic function capable to convert any type of geometry supported by Rhino into an ON_Mesh?
I wrote the following piece of code, but I would need a review please.
– What are the pros and cons of my solution and yours?
– Can you confirm that CRhinoObjectRef::Brep() returns a brep pointer also for any subd, and not only for breps, a surfaces, or edges?
– Where is stored the brep pointed by its returned value? Into the CRhinoObject? I need to know how long the returned pointer will remain valid.
– Since CRhinoObjectRef::Brep() is const, I suppose the brep is not computed by that function. Does it mean that any subd, brep, surface and edge internally contain a brep representation?
– What is a proxy brep? extrusions and subds return always a proxy brep?
// Input parameters
const ON_MeshParameters in_mesh_params;
const CRhinoObject* in_object = nullptr;
ON_SimpleArray<ON_Mesh*> out_mesh_list;
const CRhinoObjRef obj_ref(in_object);
Description:
If the referenced geometry is a brep, a surface, or an edge,
this returns the brep.
Returns:
brep or NULL.
See Also:
CRhinoObjectRef::Geometry
CRhinoObjectRef::GeometryType
Remarks:
Note that the brep may be a proxy brep from an extrusion or subds.
This has been the case since 2010 for extrusions and always
has happened for subds.
const ON_Brep* brep = obj_ref.Brep();
if (brep != nullptr)
obj_ref.Brep()->CreateMesh(in_mesh_params, out_mesh_list);
