As far as I know, the difference between a function called SetKnot and InsertKnot is that a set function requires that memory has already been allocated, whereas an insert/append/push_back is able to extend the memory in order to insert a new element.
Keeping this in mind I was very surprised to see that InsertKnot does not extend the Knot vector and does not insert a new knot value. Also, I was a bit puzzled when I tried to set a value on unallocated memory and saw that the program was not crashing.
What am I missing here?
ON_NurbsSurface nurbs_surface( degree : 3, true, degree+1 : 4, degree+1 : 4, u_size : 11, v_size : 7 );
// size of each custom knot vector is n = #cvs + #degree + 1 (https://en.wikipedia.org/wiki/Non-uniform_rational_B-spline)
auto ku = ct::generate_knotvector( degree : 3, u_size : 11 );
auto kv = ct::generate_knotvector( degree : 3, v_size : 7 );
std::cout<< "Ku size = " << ku.size() <<std::endl; // out: 15
std::cout<< "Kv size = " << kv.size() <<std::endl; // out: 11
std::cout<< "(B) ON Ku size = " << nurbs_surface.KnotCount(0) <<std::endl; // out: 13
std::cout<< "(B) ON Kv size = " << nurbs_surface.KnotCount(1) <<std::endl; // out: 9
for (int i = 0; i < ku.size(); ++i)
if (i < nurbs_surface.KnotCount(0))
double old_knot = nurbs_surface.Knot(0,i);
nurbs_surface.SetKnot(0, i, ku[i]);
std::cout<< "setting knot U[" << i << "] = " << old_knot << " -> " << nurbs_surface.Knot(0,i) <<std::endl;
else
nurbs_surface.InsertKnot(0,ku[i]);
std::cout<< "inserting knot U[" << i << "] = " << ku[i] << " -> " << nurbs_surface.Knot(0,i) <<std::endl;
for (int i = 0; i < kv.size(); ++i)
if ( i < nurbs_surface.KnotCount(1) )
nurbs_surface.SetKnot(1,i,kv[i]);
else
nurbs_surface.InsertKnot(1,kv[i]);
std::cout<< "(A) ON Ku size = " << nurbs_surface.KnotCount(0) <<std::endl; //out: 13 ???
std::cout<< "(A) ON Kv size = " << nurbs_surface.KnotCount(1) <<std::endl; //out: 9 ???
I have also tried using:
nurbs_surface.ReserveKnotCapacity(0, ku.size());
nurbs_surface.ReserveKnotCapacity(1, kv.size());
without much success, i.e. did not make a difference.
Full output:
u_size = 11
v_size = 7
Ku size = 15
Kv size = 11
(B) ON Ku size = 13
(B) ON Kv size = 9
setting knot U[0] = -0.54400643667890747 -> 0.00000000000000000
setting knot U[1] = 11.83328550806970547 -> 0.00000000000000000
setting knot U[2] = 10.02935199996707283 -> 0.00000000000000000
setting knot U[3] = -0.53781791885622077 -> 0.00000000000000000
setting knot U[4] = 12.21595752388964939 -> 0.12500000000000000
setting knot U[5] = 10.00900402987057625 -> 0.25000000000000000
setting knot U[6] = -0.49935833839056237 -> 0.37500000000000000
setting knot U[7] = 12.54947070285905752 -> 0.50000000000000000
setting knot U[8] = 9.88254816181600759 -> 0.62500000000000000
setting knot U[9] = -0.46806856448411210 -> 0.75000000000000000
setting knot U[10] = 12.86163479356979344 -> 0.87500000000000000
setting knot U[11] = 9.77966676080580655 -> 1.00000000000000000
setting knot U[12] = 0.15298294665255666 -> 1.00000000000000000
inserting knot U[13] = 1.00000000000000000 -> 0.00000000000000000
inserting knot U[14] = 1.00000000000000000 -> 0.00000000000000000
(A) ON Ku size = 13
(A) ON Kv size = 9
