Hey,
I’m having a problem with inserting knots into a nurbscurve. The original knot vector is […,4.38816991,4.38816991,4.38816991,4.3881700452521,4.3881700452521,4.3881700452521,…]
The knot to be inserted is 4.38816997743766. The function InsertKnot() returns true, but the knot vector is not changing. I know that these values are very close. Even the span is not recognized by Rhino. I assume this is because of a certain tolerance. Is it an absolute tolerance or a relative?
Is there a way to work around this without generating a completely new curve, e.g. by scaling or shifting the knot vector? The original curve was derived with Rhino but the knots to be inserted are defined elsewhere and I cannot change this.
Thank you!
