I checked this branch out this morning. It definitely appears like it’s working better, but it still gives the following error:
In file included from opennurbs.h:52:0,
from opennurbs_3dm_attributes.cpp:17:
opennurbs_lock.h:118:44: error: use of deleted function ‘std::atomic::atomic(const std::atomic&)’
std::atomic m_lock_value = ON_Lock::UnlockedValue;
In file included from opennurbs_system.h:594:0,
from opennurbs.h:29,
/usr/include/c++/5/atomic:612:7: note: declared here
atomic(const atomic&) = delete;
/usr/include/c++/5/atomic:616:17: note: after user-defined conversion: constexpr std::atomic::atomic(std::atomic::__integral_type)
constexpr atomic(__integral_type __i) noexcept : __base_type(__i) { }
opennurbs_statics.cpp:424:21: error: uninitialized const ‘ONX_ModelTest::Unset’ [-fpermissive]
const ONX_ModelTest ONX_ModelTest::Unset ON_CLANG_CONSTRUCTOR_BUG_INIT(ONX_ModelTest);
In file included from opennurbs.h:164:0,
from opennurbs_statics.cpp:1:
opennurbs_extensions.h:1631:16: note: ‘const class ONX_ModelTest’ has no user-provided default constructor
class ON_CLASS ONX_ModelTest
opennurbs_extensions.h:1634:3: note: constructor is not user-provided because it is explicitly defaulted in the class body
ONX_ModelTest() = default;
opennurbs_extensions.h:2037:43: note: and the implicitly-defined constructor does not initialize ‘unsigned int ONX_ModelTest::m_model_3dm_file_version [3]’
unsigned int m_model_3dm_file_version[3];
(edited to add) That worked, now the only issue seems to be missing uuid_generate, and that one I’ve solved before, even if I don’t quite remember how.
opennurbs_sort.cpp:69:3: error: no matching function for call to 'qsort_r'
qsort_r(base,nel,width,context,compar);
printf/scanf
such as:
opennurbs_string_format.cpp:813:13: error: no matching function for call to ‘vsnprintf’
opennurbs_string_scan.cpp:159:10: error: use of undeclared identifier ‘swscanf_l’
opennurbs_string_scan.cpp:164:10: error: ‘_vswscanf_s_l’ was not declared in this scope
return _vswscanf_s_l(buffer, format, ON_Locale::InvariantCulture.NumericLocalePtr(), args);
etc.
It seems opennurbs does NOT support GNU LINUX well?
I’ve used and tested OpenNURBS with Clang on Linux Mint 18. This works great for my import_3dm blender add-on using rhino3dm. This is the Python and JavaScript wrapper around OpenNURBS. It works great on Linux as well, using the Clang compiler. You’ll find there is a branch with some fixes that make it all compile on Linux - see the lib folder in rhino3dm
Don’t delete the freetype and zlib source code - those are used on other platforms. I also think the preference is that we use the source code we bundle with OpenNURBS for increased control over those libs, in case bugs need to be fixed then and there.
I checked out the Linux modification and built with Clang 8.0.0-3 under Ubuntu 19.04, however, I still obtained the following ERROR messages:
In file included from opennurbs_3dm_attributes.cpp:17:
In file included from ./opennurbs.h:29:
In file included from ./opennurbs_system.h:115:
./opennurbs_system_runtime.h:82:2: error: unterminated conditional directive #if defined(ON_RUNTIME_APPLE)
./opennurbs_system.h:244:2: error: Update OpenNURBS to work with new pointer size. error Update OpenNURBS to work with new pointer size.
In file included from opennurbs_3dm_properties.cpp:17:
In file included from opennurbs_annotationbase.cpp:17:
In file included from opennurbs_archive.cpp:17:
In file included from opennurbs_arccurve.cpp:17:
In file included from opennurbs_archive_manifest.cpp:17:
In file included from opennurbs_arc.cpp:17:
In file included from opennurbs_3dm_settings.cpp:17:
./opennurbs_system.h:716:2: error: Either ON_64BIT_RUNTIME or ON_32BIT_RUNTIME must be defined. error Either ON_64BIT_RUNTIME or ON_32BIT_RUNTIME must be defined.
./opennurbs_system.h:743:2: error: OpenNURBS assumes sizeof(void*) is 4 or 8 bytes error OpenNURBS assumes sizeof(void*) is 4 or 8 bytes
In file included from ./opennurbs.h:35:
./opennurbs_defines.h:335:25: error: unknown type name ‘ON__UINT_PTR’
bool ON_IsNullPtr(const ON__UINT_PTR ptr);
./opennurbs_defines.h:338:25: error: unknown type name ‘ON__INT_PTR’
bool ON_IsNullPtr(const ON__INT_PTR ptr);
./opennurbs_defines.h:1237:5: error: unknown type name ‘ON__UINT_PTR’
ON__UINT_PTR model_serial_number
./opennurbs_defines.h:1242:64: error: unknown type name ‘ON__UINT_PTR’
ON::LengthUnitSystem (func_ModelLengthUnitSystemCallback)(ON__UINT_PTR)
./opennurbs_defines.h:1237:5: error: ./opennurbs_system.h:716:2: error: Either ON_64BIT_RUNTIME or ON_32BIT_RUNTIME must be defined. error Either ON_64BIT_RUNTIME or ON_32BIT_RUNTIME must be defined.unknown
./opennurbs_system.h:743:2: error: OpenNURBS assumes sizeof(void) is 4 or 8 bytes
type name#error OpenNURBS assumes sizeof(void*) is 4 or 8 bytes
‘ON__UINT_PTR’
./opennurbs_system.h:743:2: error: OpenNURBS assumes sizeof(void) is 4 or 8 bytes error OpenNURBS assumes sizeof(void*) is 4 or 8 bytes
In file included from ./opennurbs.h:40:
./opennurbs_uuid.h:382:3: error: unknown type name ‘ON__UINT_PTR’
ON__UINT_PTR m_ptr = 0;
./opennurbs_defines.h:338:25: error: In file included from unknown type opennurbs_annotationbase.cppname :'ON__INT_PTR’17:
./opennurbs.h:40:
bool ON_IsNullPtr(const ON__INT_PTR ptr);./opennurbs_uuid.h:
382: ^
In file included from ./opennurbs.h:47:
./opennurbs_locale.h:28:3: error: unknown type name ‘ON__UINT_PTR’
ON__UINT_PTR
./opennurbs_system.h:743:2: error: OpenNURBS assumes sizeof(void) is 4 or 8 bytes error OpenNURBS assumes sizeof(void) is 4 or 8 bytes
ON__UINT_PTR
In file included from ./opennurbs.h:50:
./opennurbs_compstat.h:648:15: error: unknown type name ‘ON__UINT_PTR’
bool InList(ON__UINT_PTR x) const;
ON__UINT_PTR
^./opennurbs_defines.h:1242:64: error: unknown type name ‘ON__UINT_PTR’
ON::LengthUnitSystem (*func_ModelLengthUnitSystemCallback)(ON__UINT_PTR)
./opennurbs_compstat.h:656:18: error: unknown type name ‘ON__UINT_PTR’
bool AddToList(ON__UINT_PTR x);
ON__UINT_PTR
./opennurbs_compstat.h:672:27: error: unknown type name ‘ON__UINT_PTR’
void ExpertAddNewToList(ON__UINT_PTR x);
./opennurbs_compstat.h ON__UINT_PTR m_ptr = 0;
./opennurbs_compstat.h:684:5: error: unknown type name ‘ON__UINT_PTR’
ON__UINT_PTR m_a = nullptr;
ON__UINT_PTR
ON__UINT_PTR
./opennurbs_compstat.h:672:27:./opennurbs_compstat.h :656:error18: : unknown errortype: name ‘ON__UINT_PTR’
unknown type name void ExpertAddNewToList(ON__UINT_PTR x);
‘ON__UINT_PTR’ ^
./opennurbs_compstat.h:686:38: error: unknown type name ‘ON__UINT_PTR’
bool InBlock(size_t sorted_count,ON__UINT_PTR p) const;
ON__UINT_PTR* m_a = nullptr;
./opennurbs_compstat.h./opennurbs_compstat.h::691672:24:: 27error: error: : unknown typeunknown nametype ‘ON__UINT_PTR’
name ‘ON__UINT_PTR’
static int Compare(ON__UINT_PTR* lhs, ON__UINT_PTR* rhs);
./opennurbs_compstat.h:684:5: error: unknown type name ./opennurbs_compstat.h’ON__UINT_PTR’
:691:43: ON__UINT_PTR* m_a = nullptr;
./opennurbs_compstat.h:691:24: error: unknown type name ‘ON__UINT_PTR’
./opennurbs_compstat.h: ^672
./opennurbs_compstat.h:704:26: error: unknown type name ‘ON__UINT_PTR’
void Internal_AddValue(ON__UINT_PTR x);
./opennurbs_compstat.h:691:43: error: unknown type name ‘ON__UINT_PTR’
./opennurbs_locale.h:28:3:./opennurbs_compstat.h:684:5: error: unknown type name ‘ON__UINT_PTR’
ON__UINT_PTR
In file included from ./opennurbs.h:51:
./opennurbs_progress_reporter.h:85:31: error: unknown type name ./opennurbs_compstat.h:704:26: ‘ON__UINT_PTR’
void (*callback_function)(ON__UINT_PTR context,double fraction_complete), void Internal_AddValue(ON__UINT_PTR x);
fatal error: too many errors emitted, stopping now [-ferror-limit=]
./opennurbs_progress_reporter.h:85:31: error: unknown type name ‘ON__UINT_PTR’
void (callback_function)(ON__UINT_PTR context,double fraction_complete),
static int Compare(ON__UINT_PTR lhs, ON__UINT_PTR* rhs);
static int Compare(ON__UINT_PTR lhs, ON__UINT_PTR rhs);
ON__UINT_PTR
20 errors generated.
make: *** [makefile:69: opennurbs_3dm_attributes.o] Error 1
make: *** Waiting for unfinished jobs…
make: *** [makefile:69: opennurbs_annotationbase.o] Error 1
make: *** [makefile:69: opennurbs_arccurve.o] Error 1
make: *** [makefile:69: opennurbs_3dm_properties.o] Error 1
make: *** [makefile:69: opennurbs_archive_manifest.o] Error 1
make: *** [makefile:69: opennurbs_3dm_settings.o] Error 1
make: *** [makefile:69: opennurbs_arc.o] Error 1
make: *** [makefile:69: opennurbs_archive.o] Error 1
➜ opennurbs git:(master) ✗
For now to just use the CMake approach of rhino3dm and use that OpenNURBS lib that gets created for it.
This week @will is going to update the public OpenNURBS repository with the latest code changes that I tested on Linux Mint 18 also using the makefile and Clang. We can then check what the status is, since we’d the be looking at the same codebase.
