OffsetMesh bug?
Hi @Pascal,
grafik
when a mesh is offsetted Solid using _OffsetMesh command in Rhino 6 and the Flip all button is pressed once, the result is a mesh with inverted normals.
Regardless of the flip option usage, the preview is wrong. It shows a mesh with inverted normals but when the flip option is not used, it inverts the input mesh (if Delete input meshes is enabled) once completed. I wonder where is the logic ?
_
c.
Checking, thanks…
@clement - I see the first bit - the inverted normals, that is clearly a bug, but I do not follow the second part yet, about the preview - preview is wireframe, here, no indication of normal direction… I think I am missing the point of your comment…
RH-63498 Offsetmesh: Normals inverted
Hi Pascal, yes you are right about my second complain. I’ve tested this with very small offset distances on a large mesh and it appeared to look like inverted preview. So the preview is not a problem(*), only the inverted result.
(*) would it be possible that the _-OffsetMesh command disables preview when the dialog is suppressed ?
thanks for the report,
c.
