I created a Subd shape of a person’s head. I then projected a curvy line on this head from side view. I then selected the line and wrote OffsetCrv on surface and expected the whole curve to offset on my surface but I ended up having to offset on each face one by one. Not happy with that Rhino has not connected the individual separate lines which have been separately offsetted on each single face so bit by bit i had to extend each line so that it connects to the continuation of it and then join. Its a tiresome job. is there a workaround? thanks
there isn’t a OffsetCrvOnSubd, so yes I can see how this process becomes tedious. Depending on how accurate you want your result to be, what could work is to Pipe the curve instead, and intersect that pipe with the SubD.
The pipe system could be a very good test. The extrusion of surfaces wouldn’t work because it would not offset at a constant distance throughout the whole length of the curve. I think here there is a missing tool…needs to be added
