I recently had a problem with a closed planar curve that I need to offset towards the inside. What happens is that it gets broken after -0.537 of distance.
Please check the file to see the problem. I also added another very similar curve that offsets just fine as a comparison.
It looks like Segheir’s solution also works, but I wonder what the Flip component does that makes it work. Flip certainly would not have occurred to me as something to try.
As @anon39580149 stated, Flip Curve solved the issue but @Birk_Binnard I didn’t understand why it works. What’s the logic behind it? I would never thought to use Flip Curve if @anon39580149 didn’t mention it, to be honest.
Yes @Baris, it doesn’t work. Thank you for sharing!
