Offseting to the inside of a pline does not trim some of the corners
Some of the corners do not trim even though Trim is on.
When trim is on the offset command still creates triangles in corners when offset to the interior (but good when offset to exterior)
Could I have this 3dm file? Thanks.
houseexample.3dm (50.1 KB)
It is not a coplanar curve, Offset will be fine after make it as a coplanar curve via SetPt
Thank you
