I’m trying to offset brep in such a way that in a top view offset would remain same shape as the original brep. It’s not a problem in cases when the offset in top view is larger than original - I can simply cut off the unnecessary parts. Problem arises in cases where offset is smaller than original - then there is a gap in a plan view.
I understand that it’s just a nature of the offset that dictates behavior like this - but maybe someone has come across similar problem an has some solution…
For the offset I was using Sasquatch Brep offset component.
RAMP.gh (14.8 KB)
