I import many STEP files from different places. Sometimes I get strange surfaces imported that I cannot understand.
The attached for example was part of a bolt head, believe it or not.
Turning on points shows 4 corners way out in space. Shrinking the surface helps a lot but the display of the surface is still perplexing.
It’s not an earth shattering thing but if someone could shed some light on the possibilities it might save me some headaches.odd surface.3dm (30.7 KB)
Hello - RbuildEdges will sort that out - the object has (What command) seriously out of tolerance edges and vertices:
Edge Tolerances: 0.000 to 0.107
median = 0.000 average = 0.043
Vertex Tolerances: 0.000 to 0.107
median = 0.000 average = 0.021
especially compared to its size (~.25")
Do you have the step file? Can we have a look at that?
Thanks, Pascal. Tolerances is the culprit !
Sorry but the STEP files I use is proprietary to the extreme and I can’t share.
But when I see this again, and I will, I’ll know how to proceed to clean up the mess.
Speaking of STEP files, I thought I was crazy so I experimented inserting a STEP file gotten from GrabCad of a BMW M4 shell.
It took Rhino 5 1:20 to insert the file and Rhino 6 2:32 for the exact same file (“begin parsing” to “insertion point”)
So far I like using Rhino 5 better for a lot of reasons. This is just one. Mesh creation is another.
MS
Hello - can you send us that file or a link to it? In general STEP should be better in V6 - are the results in 5 comparable? For instance, what are the edge and vertex tolerances like in each? (What command)
thanks,
BTW I think I always use the default configurations for importing in each case.
Never had the occasion to change anything.
