Odbc Connection in C# x Odbc Connection in Python
Hi guys,
I was able to write a script in python to connect and query some data in a PostgreSQL database via ODBC. This is the code:
import clr
import System
clr.AddReference("System.Data")
from System.Data import DataSet
from System.Data.Odbc import OdbcConnection, OdbcDataAdapter
if CToggle == True:
    connection = OdbcConnection(CString)
    adaptor = OdbcDataAdapter(Query, connection)
    dataSet = DataSet()
    connection.Open()
    adaptor.Fill(dataSet)
    connection.Close()
    rows = []
    for row in dataSet.Tables[0].Rows:
        rows.append(list(row))
    QResult=[]
    for i in range(0,(len(rows))):
        QResult.append(rows[i][0])
else:
    QResult = 'Turn the CToggle on!!!'
(My input variables are “CString”, “CToggle” and “Query”. My output is “QResult”.)
Recently I have contact with C# and I am trying to “translate” this code. Then I do this:
  private void RunScript(string CString, bool CToggle, string Query, ref object QResult)
    if (CToggle == true)
      System.Data.Odbc.OdbcConnection connection = new System.Data.Odbc.OdbcConnection(CString);
      System.Data.Odbc.OdbcDataAdapter adaptor = new System.Data.Odbc.OdbcDataAdapter(Query, connection);
      DataSet dataset = new DataSet();
      connection.Open();
      adaptor.Fill(dataset);
      connection.Close();
      List<string> rows = new List<string>();
      foreach (DataRow row in dataset.Tables[0].Rows)
        rows.Append(row[0]);
        Print(row[0].ToString());
      QResult = rows;
      //Override component attributes
      Component.Name = "Odbc Query C#";
      Component.NickName = "OdbcQuery.cs";
      Component.Message = "v01_02/20/2020";
      Component.Description = "This component sends a query to a database using ODBC driver installed in your system\n\n------\n\nProvided by Eugênio Moreira @ LED_UFC";
      //Override component input attributes
      Component.Params.Input[0].Name = "Connection String";
      Component.Params.Input[0].NickName = "CString";
      Component.Params.Input[0].Description = "Input the connection string";
      Component.Params.Input[1].Name = "Connection Toggle";
      Component.Params.Input[1].NickName = "CToggle";
      Component.Params.Input[1].Description = "Set 'True' to start the process";
      Component.Params.Input[2].Name = "Query";
      Component.Params.Input[2].NickName = "Query";
      Component.Params.Input[2].Description = "Input the complete query in string format";
      //Override component output attributes
      Component.Params.Output[1].Name = "Query Results";
      Component.Params.Output[1].NickName = "QResult";
      Component.Params.Output[1].Description = "List with the result of the query";
So, here is the thing… When I use the Print function (inside the last foreach), I have the exact result that I want in the out output. But, when I try to build a list (rows) with the results and assing this to another output (QResult), I have a empty list.
Anyone understand this behavior? Anyone have a clue about pass to my QResult output the same list as out?
Thanks in advance!
:yellow_heart:
This is it!
Just to clarify. this is the modification that I had to make:
      connection.Open();
      connection.Close();
        rows.Add(row[0].ToString());
      QResult = rows;
The line rows.Append(row[0]); , was replaced for rows.Add(row[0].ToString());.
Many Thaks @PeterFotiadis!
