Daniel - I have fixed both your problems (the exception and perspective correction not working) in the latest release (3.0.4.60), which you can download from https://render.otoy.com/forum/viewtopic.php?f=41&t=42587
I will look at the sun position and focal length export in the next release.
Paul
Oh thanks Paul,
I almost hate to report another error window. This happens when i switch between work session files. However unlike the last error I am able to ok-click through this one without crash.
Again, any spontaneous suggestions without having to send you my elephant file structure?
Hi - I couldn’t reproduce any errors when doing a simple test with a Worksession. Are you able to reproduce this error dialog with a simple Worksession? What is the exact workflow you are using which results in this error dialog pls?
Paul
