Oblong Tiling
I am struggling with the trigonometry that underlies the tiling of these oblongs:
The circle centers are supposed to remain vertically aligned, and I believe horizontally aligned as a result aswell. But the math seems to change dependent on whether the oblongs touch on the round or the straight sides?
Hi Volker, I’m not sure what you’re asking. Could you share the grasshopper code and clarify your question?
Sure. I suppose, I could clarify some more.
I am trying to rotate a oblong through 360 degrees and tile it as above. An oblong is essentially a rectangle with semicircles at opposing ends of one direction of the rectangle. Like the shape of a horserace track.
I am close to getting the vertical displacement down using a piece-wise function. When I have that piece of code done, I’ll post it.
I’d love to have a crack at this a bit more in depth but currently bogged down with deadlines.
But the way I see it is as if it has varying degrees of semiregular tile patterns (when I’d initially expect it to be regular by default since it is a singular piece) depending on the rotation of the tiles past 90 degrees. what It’d be curious about is if it could be solve through laying down an elongated triangular tiling frame and seeing if the pieces tie together?
We would treat them all as triangles/squares but we could then overlay the arc on our “triangular” tips, quick sketch of what I mean below (missing the “tie in” triangulation in the rotated options as my hand pulse is currently failing me…):
:robot: Not necessAIrily tiling but really cool this kind of stuff can be done dynAImically :robot:
But what is it? Kangaroo? C# code?
Rhino AI, no kangaroo
Ah… So it’s not a script? It just placed a bunch of random length oblongs?
It’s a prompt which allows dynamic changes.
you need to shift the tiles in x direction an additional dx, at 0 deg rotation dx = 0. Dx = 2 (R*(cos(theta) - 1))
I think in y-direction something similar happens probably with sinus
This is what I have so far using ma’brain:
Oblong Tiling VR 1.gh (48.3 KB)
I don’t know why, but for some reason it reminds me of seals. Sea lions. Sea lions are the ones that balance balls apparently.
It’s working is’nt it? Not bad i guess
You could draw actual seals and let them dance around themself.
I still need to calculate the horizontal offset, which have no idea how to do… yet.
I didn’t look extensively at your code but the math is there.. just copy the row in x direction by the distance 2Rcos(theta) and rotate them (180 - theta)
Edit: maybe I got the sign convention wrong, however something like this should work
This is interesting but I’m too tired
Thanks for the effort.
You must have seen this topic, if not, you must now :slight_smile:
An Aperiodic Monotile - Grasshopper - McNeel Forum
Is it relevant to this thread, or are you just teasing me?
I think the logic behind the repetition is interesting.
I thought you were teasing me because I was being unnecessarily pedantic about the difference between Chair 44 and Chair 611. :laughing:
