I have a big problem exporting to .obj format: more objects with the same name result in a single object when I reopen the .obj file in c4d
I think the most convenient way to solve the issue is to batch rename al the selected objects with a python script, could you help me to write one? I only find one for windows
Would you like to rename all objects or just the ones where several objects have the same name? For those objects, would a numeric suffix suffice? (name-1, name-2, name-3, etc…). What about objects that don’t have a name?
I need to rename only objects with the same name and give a name to objects that don’t have one, but even rename all the selected objects indistinctly could be good for me. The name could be a progressive number with a suffix or simply a progressive number
Hi luja, in addition to the script above by Mitch, the _SelName command could be used to select all objects which are either unnamed or multiple objects with the same name. Under Windows, the _SetObjectName command has an option _AppendCounter=Yes which adds a suffix. Not shure if the Mac version is identical here.
If available, you may as well experiment with Rhino`s OBJ Export options and choose to export object names either as “OBJ groups” or “OBJ objects”.
