I found this:
I have to apply “ghosted” mode for 100 objects. From this script I need to select the display mode for every single object (which I want to avoid).
I don’t want to change the display mode by selecting the object in Rhino. I want to create the object using script and change the display mode at the same time (similar to “setobjectdisplaymode” option).
Hi @Kanika_Rajain ,
you can use RhinoCommon to override the display mode for your object as follows:
import Rhino
ghostedMode = Rhino.Display.DisplayModeDescription.GetDisplayMode(Rhino.Display.DisplayModeDescription.GhostedId)
for k in range(10):
obj1 = rs.AddSphere([k,0,0],.5)
rs.ObjectColor(obj1,(255,144,115))
rhinoObject = rs.coercerhinoobject(obj1)
rhinoObject.Attributes.SetDisplayModeOverride(ghostedMode);
rhinoObject.CommitChanges()
