Without any change to the computer or to the WIP, Suddenly the Obj export is failing. Both via the usual macro I always use, and manually though the export command.
I get this: Failed to save as /Users/akash/Documents/Zbrush Work/FromRhino.obj. The file writing plug-in failed.
Interesting, thank you,
it is back to working correctly now, so that may well have been the culprit.
Even though… I did do a computer restart at the time and still had the problem hours later…?
thanks a lot
Akash
