Numbering the Faces on a 20 Sided Dice
I’m hoping someone can do this in half the components that I have and get a better solution.
I want a 20 sided dice.
Opposite faces should add up to 21
The numbers should be distributed evenly, but I’m not sure on the rules of this yet.
ICOSOHEDRON_DICE.gh (16.7 KB)
The only plugin I’ve used is Weaverbird, I think. (EDIT: Text On Surface might not be native.
https://boardgames.stackexchange.com/questions/16676/is-there-a-standard-way-to-number-the-faces-of-a-20-sided-die
