I’m working in Grasshopper and I can use some advise about sequentially ordering a set of points along a curve so that I can draw a polyline through them in the correct order. Or maybe there is a better way to convert the splines in poly lines?
Thank you very much for your reply. This would be a good solution if the mesh flowed along the isocurve direction. However, the points have to follow the projected lines parallel to the Y vector (see image)
