Null values into And component produce True.
Is this problem related in some way to the Null & Empty Branches and basic arithmetic functions?
running grasshopper 1.0007
Thanks!
NullNull-True.gh (5.4 KB)Null values into And component produce True.
Thanks!
NullNull-True.gh (5.4 KB)Hmm, I think it should output null if all inputs are null. If there’s some non-null inputs then the output should only look at those. Logged under RH-47300.
That would be the behavior of “Or” operator. “And” should give “null” even if only one of A and B is “null”.
“Or” operator is bugged too, it return “false”.
